Old October 15th, 2003, 07:36 PM   #5 (permalink)
Andy B
Loose ground!
Brass is a good conductor. What you are describing sounds like a grounding problem. You can ground the bridge plate with a bare wire lying under it fed through the wiring channel & soldered to either pot.
Andy
Andy B is offline   Reply With Quote
