Old October 14th, 2003, 06:01 PM   #15 (permalink)
TeleGeir
TeleGeir's Avatar
Re: i seem to remember reading...
Originally Posted by 11 Gauge
...that to really take advantage of any guitar with a cavity in it, predominantly acoustics, you need some kind of saddle transducer pickup. if i remember correctly the particular article stated that electric guitar pickups almost entirely just sense the magnetic fields around them, i.e. string movement. an acoustic transducer, on the other hand, will actually sense pressures and soundwaves on wood surfaces, the interior of the guitar, etc.
That is probably correct. But I suspect that a true acoustic body will react differently to the vibrations from the strings through the bridge, and that response will then spread back to the strings. Now a normal Thinline has so thick walls and lids that the difference doesn't matter. But put the same pickup on a solid tele and a jumbo acoustic and I am pretty sure you would notice the difference.
And Thinlines do look sweet! 8)
Plus - assuming it doesn't matter much to the sound - me and my back like them light...
Geir :)
"This is a room in Paul's house."
TeleGeir is offline   Reply With Quote
