Originally Posted by Cassidy
Can't I damage it by leaving it on with no speaker load?
Yes you can damage it that way.
1. Check your guitar cable.
2. Check your amp's input jack.
3. Check your guitars output jack.
4. Check both the speaker's terminals, as well as the 1/4" speaker jack to make sure the connection is good (may "look" OK, so look closely).
If you blew a mains fuse there would be no lit up tubes (no lit up anything, for that matter).
