Old November 17th, 2006, 12:20 PM   #101 (permalink)
T3L3CAST3R scr33nag3r
T3L3CAST3R scr33nag3r's Avatar
Originally Posted by t0m
I use the same power supply and power my rat with it. I bought a battery snap adaptor for a visual sound 1-spot and just use that.
You can also make em yourself easily if you have a battery snap handy. Just cut off the plug on one end, solder the centre/core wire to the black/negative wire coming off the battery snap and the bare strands twist together and solder to the red/positive wire off the battery snap. cover with electrical tape and you're done! Works great, its what I'm using to power my wah.
thanks for replying
however, i know nothing about electronics at all
i would use it on my RAT and wah which i believe require the same adapter.
whats this battery snap thing you're talking about?
whats the cheapest and easiest way for me to do this? I think my dad has some soldering stuff but means taking the pedals etc. over there
thanks.
T3L3CAST3R scr33nag3r is offline   Reply With Quote
