Originally Posted by Rob DiStefano
IMO, it doesn't much matter how you trim away the excess wood from the body blank because it's the the router w/top bearing bit, and the guitar outline router template, that does the real work.
So I could actually use a hand held jig saw to cut the rough shape then use the router and template?
If so, I'm a helluva alot closer to starting this than I thought
