Old August 27th, 2006, 05:05 PM   #16 (permalink)
pauare67
pauare67's Avatar
This is my pedalboard. It has 11 peds. Nothing fancy. Lots of Danelectro. Cheap but good peds. I am using a Bass Equalizer instead of a Guitar Equalizer. Bass Eq has higher range. The entire setup runs on an SKB PS-45 Stereo Pedal Board. Board can power 8 peds. The additional two that I have is powered through a 1 Spot Power Supply that can be plugged on the onboard outlets of the pedalboard. A single 1 Spot Power Supply can power 5 peds. If I am going to overdo it, I can run 12 more peds on this board. Yeah but what for??? The SKB is similar to a luggage. It weighs a TON without the effects and weighs a megaton with the effects.
Around the world in two years.
pauare67 is offline   Reply With Quote
