Old May 19th, 2006, 03:26 PM   #11 (permalink)
PraiseCaster
PraiseCaster's Avatar
Here's all the mods, and a warning:
DISCLAIMER:
The following modifications will void your warranty. Do the modifications at your own risk. If you do not know how to safely work with high voltage circuits, STOP. Refer modifications to qualified service persons. High voltage can kill you. DEATH IS PERMANENT. The author and this site accept no liability for anything you do or for damages resulting directly or indirectly from the following modifications regardless of whether or not the modifications are performed according to this article. Proceed at your own risk.
Unplug the amp from the power source. Wait a minute for the high voltage power supply capacitors to drain. Access the amp chassis by first removing the speaker baffle assembly. Remove the louvered metal tube shield on the back. Remove the output tubes and set them in a safe place. Unbolt the chassis and remove it through the front of the cabinet.
NOTES: The changes to the original circuit are marked in red on the modified schematic.
The original schematic shows a 1.5 amp fast blow fuse. The chassis on my 2003 model is marked �2A Fast Blow� and does indeed have a 2A fuse.
When installing replacement resistors, use resistors of � watt rating or greater. Do not use � watt resistors in high voltage circuits.
The output tube bias circuit is adequate. I did not attempt to modify it as a variety of 6L6GC and 5881 tubes were within normal dissipation ratings when simply installed into the amp. YMMV.
ELIMINATING HUM
The biggest issue with a G40V amp is the hum which is caused by poor ground wiring. To eliminate it, modifications will need to be performed in two areas. Familiarize yourself with the modified schematic. The goal will be to ground the preamp circuitry to the chassis at the input jack and the output stage circuitry to the chassis at the output jack.
1. Replace the input jack with a metal shorting Switchcraft unit. Remove the 1M resistor from the old jack and attach it across the new jack. Attach the shielded input cable ground, tone control board ground and the black ground wire from the old jack together on the ground lug of the new jack.
2. Remove the knobs and potentiometer mounting hardware and carefully work the potentiometer PCB past the power supply filters to gain access to the foil side of the board. Refer to the filament/LED circuitry on the schematic. We want to cut the ground plane for the two, 100 ohm, 1-watt resistors between the resistor/LED circuit and the tone control ground. This will leave the tone circuit grounded at the input jack via the black wire on the other end of the PCB. Tack-solder a 22ga wire on the PCB at the junction of the two 100 ohm resistors. Connect the other end of the wire to the chassis ground at the green wire from the power cord adjacent to the power supply board. This moves the resistor/LED circuit ground point to the chassis. Filament circuit grounding is no longer through the tone control circuit ground.
59 Bassman/Marshall Type Tone Modifications
The circuit of the G40V is based on the 59 Fender Bassman, which was also the basis of the original Marshall amps. Though lacking a tube rectifier, we can voice the amp to sound more like it�s predecessors.
1. Lift the signal lead from the input jack at V1 pin2. Solder one end of a 33K ohm resistor to V1 pin 2. Slip a piece of shrink tubing over the signal lead. Attach the signal lead to the other end of the resistor. (Keep the resistor leads short.) Shrink the tubing over the resistor to insulate the connections.
2. Lift the wire from V2A grid, at the tube socket. Insert a 68K ohm resistor in series with the grid, as in item 1 above. This simulates the Miller Effect high frequency roll off in the Bassman channel mixer circuit, which the G40V lacks.
3. Change C12 from a .001mfd to a 220pf silver mica.
4. Change R19 from a 33K ohm resistor to a 56K ohm resistor.
5. Remove C13.
6. Change R26 from a 100K-ohm resistor to a 27K ohm resistor.
7. Install a 47pf, 600V capacitor between the plates of the PI driver, V3.
Presence Control
Here�s where things get a little tricky. Read this through a couple of times and check the schematic before proceeding. The presence control circuit of my 2003 G40V does not match the popular schematic. The modifications schematic has what my amp contains drawn in a box and noted. We want to modify the circuit to the Bassman style.
Remove the 4K7 resistor from the tone control PCB. Remove the .1/400V Presence cap and save it for later. Carefully cut the trace running between the presence pot center wiper and the low side of the pot. Install an insulated jumper wire between the ground side of the 4K7 resistor you removed to the high side of the where the .1/400V cap was. The low side of the presence potentiometer should now be grounded. Install a new .1/100V green poly cap from Radio Shack between the pot center wiper and ground. Remount the tone control PCB.
More Bottom
Take the .1/400V cap you just removed from the presence control circuit and replace the .022uf cap at C17 with it.
Reassemble the amp and install the tubes.
After the above modifications I can dime both the volume and master controls and the hum level is lower than the hiss of the amplifier. With a Stratocaster, the amp gets great Hendrix tones and cleans up as the guitar volume is rolled back. The amp sounds louder and has much more low end, even with the stock ten inch speaker.
One could go further toward 59 Bassman voicing by the following:
1. Change R25 to 82K ohms.
2. Remove C21 and C9.
3. Move the R26 feedback connection from the 8 ohm output tap to the four ohm tap.
4. Change C19 and C20 to .1mfd, appropriate voltage rating.
5. Remove R3 and install a choke.
Here's the schematic diagram with all the mods in red:
http://img.photobucket.com/albums/v6...mods120505.gif
I've had all the mods performed on my amp, plus I have some great NOS tubes installed, though I heard one with all the mods and only the stock chinese tubes, and it sounds almost as good!
I'm tossin around the thought of trying a different speaker, but with all the mods now, this speaker sounds really sweet! For kicks I still might try out a Celestion Greenback, and an Eminence Patriot "Delta Demon", just too see what they sound like. At this point I am not going for any drastic changes to my amps performance or tone, but just maybe tweak it a bit, and see how she sounds......
PraiseCaster is offline   Reply With Quote
