Old March 6th, 2006, 03:31 PM   #10 (permalink)
TELEkinetic
TELEkinetic's Avatar
Originally Posted by The String King
Oh god! I am about to install some Kluson tuners onto my guitar! I will be careful, I don't want this problem!
By the way, I was thinking of putting masking tape over the back of the head, where I need to drill the holes, make pencil marks through the back of the screw holes in the tuners, and going from there. Basically what you did... Did it work all right?
Thanks.
Yes.
If you are putting in vintage style tuners:
1. Press the bushings in so the tuners will center in the holes
2. Cover the holes with painting tape (easy removal) and press through each hole with a ball point pen or other implement large enough to fill the hole
3. Place all tuners in the holes and line up with a straight edge.
4. Mark the first and last holes.
5. Use your straight edge and connect those marks making sure you bisect all holes evenly.
6. Place tuners back into holes and mark the position where tuner screw openings meet the bisecting line.
7. With a scratch awl or other pointed implement, mark each location.
8. Drill correct size holes through the tape
Guitars better than women:
You can have a guitar professionally adjusted......
TELEkinetic is online now   Reply With Quote
