Made a few cross cuts 20 inches long, working around some bad knots.... Got these four pieces out of the same board.......I wanna joint one edge on each and glue up two blanks, but Im not even sure I've got the grain together as it should be..? Help ! Looks like this board was rough sawed about 2 3/8" on one side and a full 2 inches on the other.......Should be plenty to work with I think. The way I see it, the bottom of the boards as they are in the pic should be the back side of the blank and the top side the front of the blank ? Am I correct or do I need to change the way Im looking at it before I drag out the jointer and the thickness planner? Thanks
Jeff
