All,
I'm looking to purchase the PT/OT's for the 5f1 and 5e3 kits that I got from Boothill Amps.
The 5f1 will be going into a 10" cab from Memphis Amps, and I plan to use a 10" Weber sig 8ohm speaker instead of the usual 4ohm 8".
http://www.musicrnr.com/cabinets.htm
I saw today that AES is having a 10% off sale for the month, and they appear to ship orders over $99 for free which I will easily surpass with this order.
So with that in mind, I'm looking for advice/confirmation about what to order.
Looking on the site they appear to have two PT's which are described as "Replacement for Princeton, Princeton Reverb, Champ, Vibro-Champ, and Tweed Deluxe". So out of that list it looks like the same part # covers both my 5f1 and 5e3:
http://www.tubesandmore.com/products/P-T290AX
I have not tried this one.
http://www.tubesandmore.com/products/P-TF22772
I use this one all the time. I like it. It has been reliable and strong.
As for OT's since I'm planning on using a 8ohm 10" on the 5f1, the same 8ohm used on a 5e3, would I therefore use the same OT for both as well?:
http://www.tubesandmore.com/products/P-T1750E
http://www.tubesandmore.com/products/P-TF22913
Either of these will work for the 5E3, but not for the 5F1.
The 5F1 requires a different OT (look for single ended type)
Here is one that looks good.
http://www.tubesandmore.com/products/P-T125CSE
So given that I'm going with a 8ohm speaker on both the 5f1 and 5e3 builds, would the above PT/OT's be correct for both builds? No, see above.
Thanks,
-TurtleFang
