before you change anything from stock standard string it up and see how it comes up under load -you may have enough adjustment in the bridge to compensate
avoid fiddling with the neck -if it goes of flat and parralel to the plane of the fretboard you will be sorry
drop the floor of the pocke using a 1/2" deep pattern folower bit in your router
you won't need a template - dont take off much 1/32 can make all the difference
ray
