Old May 31st, 2012, 03:30 PM   #23 (permalink)
Tony474
Originally Posted by bigbandtele View Post
Sounds like a ZT Lunchbox kinda gig to me.
Maybe, maybe not. Depends on how much clean volume is required. I recently bought a Lunchbox and, despite all the hype and euphoria on line, I've found that even using the jack-plug trick it still doesn't have the clean headroom even of my Roland Cube 20X, which I do find just about loud enough for some small gigs with the four-piece outfit I usually work with.
On the other hand, the Cube 20X has a fairly middly sound on its "JC Clean" channel, which is pretty reasonable but I wouldn't describe it as particularly Fendery.
I can't comment on the Pathfinder 15R as I've not tried one yet, but impressions here seem very positive and if it's as loud clean as the little Roland it may well be something to consider. However, if size is an important factor, it appears to be physically a bit larger than the Cube 20X, despite having the same size speaker.
Proud to be The Man From Uncool.
I cried because I had no shoes - until I met a man who had no feet...
Tony474 is online now   Reply With Quote
