Old May 14th, 2012, 04:55 PM   #24 (permalink)
peteycaster
peteycaster's Avatar
Hi Woody. Thanks for the feedback on the VRM now you've had a chance to use it on a project. Same as Geoff I often use more than one EQ. I use the standard Cubase 4 band EQ to cut lows and highs and little boosts here and there, and then use other ITB eq's for finer cuts. I guess as long as you're not cutting in one and boosting the same frequency in the other I can't see it being a problem. This assumes the EQ used doesn't colour the sound noticeably but these ears at least aren't good enough to notice that.
peteycaster is offline   Reply With Quote
