Old May 7th, 2012, 12:50 PM   #3 (permalink)
phdinfunk
Alright, this is helpful. Thank you.
So, I should wire the volume pots so that if the volume of one is at zero, and I put the switch in the middle, no sound will come out (because the output is connected to center lug rather than the pickup). Is that correct? Or is there another important aspect to this kind of sound?
Also, dagger, the pickups Curtis made me fit into a jazzmaster and don't have pole height adjustment. Maybe I could send it back to him and get that fixed. I see no reason he couldn't use adjustable poles instead of the fixed rods in there.
If I were going to send it back, does Alnico II have less mid-range resonance than five, or anything along those lines?
phdinfunk is offline   Reply With Quote
