on a strat?...without the springs on the base of the block pulling against the strings.. or a block wedged against the block in the cavity..
it'd be hard to hardtail it.... tightening the strings to pitch would bend it up off the body unless you screwed it down at the back somehow?...
"by degrees the flood of music drove all speculations out of his mind. It was as though it were a kind of liquid stuff that poured all over him and got mixed up with the sunlight that filtered through the leaves."
