Originally Posted by Joshmc5150
It's a aftermarket for sure... Has a tummy cut and top mount string on bridge only piece. It's looks like the owner painted it sea foam green and then did a nitro shot over it. The finish isn't a poly feel to it... And peels off like piece of plastic on a pickguard of a new guitar except it's brittle.
I actually plan to peel the rest of it off since its so easily done.
Sea Devil's suggestion could be spot on. If it's as thin us you say it doesn't sound like a modern poly finish. If it comes off that easy and you like it better without it your problem is solved anyway or try Sea Devil's suggestion to see if that will hurry it along.
CS 51 Nocaster, "Nashcaster"/Nashville>Nocaster conv., MIM>Nashville conv./Onamac Tall Blues pups, Squier CVC/Keystones pups, CV 60's Jazz Bass, Matt Freeman PBass/Wilde P46 pup, Taylor 414CE. Roland Cube 40xl, Bugera v5, Roland BC 60, tc BG250, GK MB112.
