Now that I have the fretboard glued to the neck I can turn my attention to gluing the book-matched top and the three piece back. The top is about 3/8th of an inch thick and difficult to clamp. I clamped two pieces of wood to each side of the top to a table, so that the wood two pieces of wood are pressed tightly against each other. I used masking tape help insure that the pieces lined up properly. I then closed the book-match so that the interior edges are up. I apply the glue to one edge, press them together.
_web.jpg)
I clamped down three pieces of wood on top of the wood to keep it from popping upon the edges, and to hold the center in place. I then placed about 60lbs of weights on top of the center board. I let this sit over night.
_web.jpg)
The next day the top had even seem with a little excess glue that I'll sand off.
Next up, I'll glue up the back.
