Old March 27th, 2012, 07:28 PM   #5 (permalink)
Glen W
Glen W's Avatar
Is this an export thing? The footswitches I've seen on this side of the pond use Heyco strain relief bushings where the cable enters the pedal.
At the typical Fender 2-button footswitch you need:
Ground - provided by the reverb cable's shield, common to both switches.
Reverb switch return - the signal wire in the shielded cable.
Vibrato switch return - the separate (white) wire inside the cable jacket.
A stereo jack and plug should work. Might make funny, loud noises if it's ever plugged or unplugged while the amp is on...
Glen W is offline   Reply With Quote
