Old March 26th, 2012, 12:03 PM   #8 (permalink)
chezdeluxe
[QUOTE=chezdeluxe;4036345In my strat which has all 7 combinations available I have the RWRP pickup in the neck position because I use bridge/middle the least and prefer to have hum cancelling on bridge/neck and middle /neck.[/QUOTE]
Originally Posted by sjtalon View Post
So a guy gets a set (position wound correct) that has a NORTH neck, and the bridge and middle are SOUTH.
Then put in a p/p pot for a neck on switch ( so you get N&B pup)
Retain the Strat-O-Tone, get 7 way and noise cancel in two positions.
Yes sjtalon thats what I said.
I think the OP's point is that if you want to try Bridge/Neck combination very easily just swap the neck and middle pickups in the pickguard. You can make your mind up about more permanent alterations depending on whether you like what you hear
"Life is mostly Froth and Bubble" Adam Lindsay Gordon
chezdeluxe is offline   Reply With Quote
