Old March 26th, 2012, 10:40 AM   #39 (permalink)
OpenG Capo4
OpenG Capo4's Avatar
Originally Posted by alexlaguna29 View Post
Nice progress! Question: I've got exact same bandsaw as you. What blades are you using? I am using 80" bosch from Lowes, but for some reason they are leaving some nasty burn marks on the wood. I don't see that yours are as bad as mine.
Craftsman, 1/4 x 80" 15tpi
Its just the "general scrolling" blade. Does a good job cutting outlines, but it does leave burn marks on maple sometimes. I cut outside the lines to compensate for this, and bring maple closer to the line on the ROSS (which can also burn it if I'm not careful).
I have a 1/2" blade in it now which cuts great but doesn't scroll much. So finishing the scrolling cuts on that neck blank I had to take material off in little bites.
If its .05 too loose, no one will ever know. If its .05 too tight, everyone will know.
OpenG Capo4 is offline
