Old March 23rd, 2012, 03:39 PM   #4 (permalink)
Jakedog
Jakedog's Avatar
Or, don't touch your trussrod. If you can put very slight pressure behind the nut, and stop the buzz, you don't have enough break angle on that string.
Put on a new string, and use a few more windings. That will put the bottom of the string wrap down closer to the peg head, increasing the down angle of the G string. This should solve your problem.
I don't play MIM guitars, but if I remember right, they only have one strings tree right? On the E and B? If you really want to solve the problem for good, and not have to remember to extra wrap your G, just add a second tree on the G and D strings. That oughtta do it. If it already has a tree on the G and D strings, then a little adjustment might be in order. Worst case scenario, a new nut.
It's not a mini-van, it's a manly van, and it's awesome.
Jakedog is offline   Reply With Quote
