Old March 21st, 2012, 10:15 PM   #18 (permalink)
Midnighttoil
Hey, Andrew, I noticed that the board that you're edge planing in the picture is warped. I've found that when I work with even slightly warped boards, I must reach appropriately square and parallel sides before I join. It doesn't matter if you're using hand or power tools; square is square. If this is making you nuts, then it sounds like a workflow or process problem. Six guitars at a time has great potential for crazy making! Good luck.
Midnighttoil is offline   Reply With Quote
