Originally Posted by Skiroy
So do you have to turn down the amp ever time to change any cables,guitars ect.? I didnt realize this would blow a speaker.
I wouldn't leave the signal hot while changing guitars/cables, if for nothing else than because that loud pop and scratch is really an awful sound to my ears. I use a boss tuner pedal when changing out guitars because it mutes the signal when you step on it. You could also pull the cable out of the amp halfway when changing out guitars and doesn't pop for some reason. I'm not sure why it doesn't pop when taking the cable out of a turned up amp though.?
