Originally Posted by jonal335
Great steels - I had the opportunity to play one quite a bit years ago. You just made me think that maybe I could build a replica! Good luck and please post your progress...
Hey have been working up info on the steel and found out this if you do plan to make one as well.
Scale- 22.5''
Nut spacing- 55mm (8) = 7.86mm
Bridge spacing- 68mm (8) = 9.71mm
Pickup(s) output- 10.5 kΩ
Full Length- 28 3/4'' (73cm)
Width- 12 1/4'' (31.1cm)
Front neck thickness 2 1/4
Back neck thickness 1 3/4
this is some of the stuff i have so far on it
