Old March 6th, 2012, 07:53 AM   #54 (permalink)
JBennett
Package is still on its way. Cleaned up power supply wiring a bit and soldered in the two 100 ohm resistors on my octal socket. And soldered up the OT leads to the RCA out. And crimped a nut mount collar on my rectifier ground.
Outlet works, and the PT fires up a-okay. Jewel lamp glows, just above 130vdc before the diodes on the rectifier and just over 250vdc after they pass through the rectifier. 8ish vac on the greens. 130vac on the primaries. Something like that. Once it's all wired up I'll photograph all the readings.
Jacks have resistors and are installed.
JBennett is offline   Reply With Quote
