Its a choppped up tobacco product in a can. Sometimes called, "snuff". Grab a pinch, put it between your cheek/lip and gums. Just make sure you spit "the juice" out, or you gonna turn green!
Then there is chaw, or chew tobacco, which is leaf type (think Beachnut). You grab a wad, shove it your mouth. You can "gnaw" on it a lil bit, but mostle just park it between check and gum. Again, spit the "juice" out or dizzy/upset tummy with green gills comin your way.
Then you have pressed tobacco, or "plugs". You chew off a chunk, and work it with your teeth, then position it between cheek/gum.
Yeah, I tried em all. I don't like chew's of any variety.
PraiseCasters G1 using TDPRI App
