Old March 1st, 2012, 10:02 AM   #17 (permalink)
Tarnisher
Tarnisher's Avatar
Thanks again, Kevin!
You're not the first to recommend Erlewine's book, so it's in my cart.
I've tried to do truss rod adjustments before, but with limited success. I understand how the rod works, and what the effect of turning the nut is, but when I actually start turning it, I sometimes can't get it to a place where the action can be reasonable without buzzing.
That happened just this week with a guitar that was recently setup by my trusted tech. He suggested I give the nut a turn until the buzz went away. I tried and tried, but just couldn't get it right, so I brought it back to him, and he did it in a matter of seconds.
That's why I thought I might benefit from actually being able to measure how far it's off and how much I've corrected it, at least until I learn to do it by feel like my tech can.
My only reservation about buying the Neck Check is that I have a wide range of scale lengths, not just Fender/Gibson. I'd like to have one tool that would work for everything.
Would the effectiveness of this tool be terribly compromised if the notches were a bit larger to accommodate multiple scale lengths? As long as there was enough metal touching the fretboard between the frets to see a gap, it seems that it wouldn't have to cover the whole space between frets. Or am I not grasping the concept?
facebook.com/householdtales
Tarnisher is offline   Reply With Quote
