Old February 24th, 2012, 09:34 AM   #115 (permalink)
Warm Gums
Warm Gums's Avatar
Originally Posted by gwjensen View Post
Stephen, how do you connect the Ipad/garage band to a simple amp with just a standard input? Is that even possible, or do you need a more advanced amp with different inputs?
I use i rig and if you have a newer amp with RCA line in for i pods etc. you can use a stereo splitter( the instructions show how).. I would think you could also use a standard cord with an mini adaptor ( the "rig" has a mini plug for headphones ) and go into a traditional line in, or even the input of a vintage amp but you would need to then defeat the speaker/cab emulation in the program ..other interfaces should be similar.
Warm Gums is offline   Reply With Quote
