Originally Posted by paulswifka
Here is a picture of my telecaster with the white pickguard, and a picture of the record I'm going to use..I've already put the template on it so see where It needs to be cut, then I will need it beveled at a 45% angel on the edges then drilled for screw holes...once the holes are drilled a slightly bigger bit will need to be drilled on top of the holes for the head of the screw to fit....
I hope that's not the original white vinyl pressing from 1989 because I'm thinking that'd be worth some money... Assuming it's the reissue that's going to be awesome. this thread has definitely given me a great idea
