Old February 22nd, 2012, 10:38 PM   #96 (permalink)
telo
Originally Posted by StephaninMelb View Post
Many of the American and European hardwoods are the same density & weight as MDF, particleboard and birch / beech plywood. An amp constructed with a solid wood enclosure would weigh more or less the same as from those man made materials.
If we're talking Fender amps, the only solid wood used was pine which is far lighter than plywood and definitely lighter than particleboard. Just for reference, I have two silverface Princeton Reverbs, one has a pine cab and the other has a particleboard cab. The pine cab is 15.1lbs; the particleboard cab is 19.5lbs. That's quite a difference for an amp that small. For something the size of a Twin/Pro, it would probably be around 10lbs. In either case, that's more than noticeable.
telo is offline   Reply With Quote
