Old February 21st, 2012, 08:36 PM   #37 (permalink)
StephaninMelb
JoYo Classic Flanger JF-07
$33 @ YooSmart
Uses the BBD circuit to achieve great metallic flange sounds, wave like chorus sounds plus rapid tremulous vibratos! 4 adjustable knobs control Speed, Regain, Width and Delay Time.
  • True bypass design minimizes tone loss
  • Aluminum alloy casing with stove finish
  • Dimensions: 11.8(L) X 8.7(H) X 3.8(W) cm
JoYo Digital Delay JF-08
$33 @ YooSmart
Features a special filter circuit to closely reproduce the sounds of analog delay. Delay time range: 25ms-600ms.
  • Aluminum alloy case with stove finish
JoYo Tremolo JF-09
$31 @ YooSmart
This is the tremolo of the beloved classic tube amplifiers--using the same photoelectric tube circuitry as the trem in those amps of old. Intensity and Rate knobs make it easy to adjust the tone and vibe.
  • Dimensions: 11.8(L) X 6.4(H) X 3.8(W) cm
JoYo Dyna Compressor JF-10
$31 @ YooSmart
A re-creation of the classic Ross compressor, with very low noise. Use the Sustain, Attack, and Level knobs to find your ideal tone. Tweek the Attack to boost your bottom end and level off high-output pickups.
JoYo Six-band Equalizer JF-11
$31 @ YooSmart
Each band provides a range of ±18dB to help you find your favorite tone. Includes the frequency bands: 100Hz, 200Hz, 300Hz, 400Hz, 800Hz, 1.6MHz and 3.2MHz.
Name:	JoYo Digital Delay JF-08.jpg
ID:	115183   Click image for larger version
Name:	JoYo Tremolo JF-09.jpg
ID:	115185   Click image for larger version
Name:	JoYo Dyna Compressor JF-10.jpg
Name:	JoYo Six-band Equalizer JF-11.jpg
StephaninMelb is offline   Reply With Quote
