Old February 19th, 2012, 03:06 PM   #25 (permalink)
Wally
onenotetom, you can use a ground breaking plug on the guitar end of that cable so that when you unplug, there is no Pop!! Unless.....you use instruments with active electronics. The grounding pop can still happen due to the grounding 'switch' connection in the jack when using a ground break plug.
