Old February 12th, 2012, 10:56 PM   #55 (permalink)
Mr Perch
Mr Perch's Avatar
I'm a N00b here, so I hope I'm not too much of a contrarian, but I think that a good improviser should look for opportunities to call attention to the "fleeting" key centers. I think that was the genius of Charlie Parker -- to be able to incorporate those slight half-step shifts in the 6ths, 7ths, 9ths and so on to reflect rapid chord changes, without sacrificing a melodic idea (the danger in playing every chord is that you could conceivably wind with a dull series of arpeggios. But the ideal should be to walk and chew gum at the same time.) Also, the more I play, the more I realize that dominant 7 chords are my friend, and you can play them when they are only implied -- like if you are playing over a sustained Dm vamp, you can throw in an A7 idea at the end of a phrase to prepare for the next phrase, and since you are playing an A7 idea, you can extend it into a C7 or a Eb7 or Gb7 idea and it all can resolve beautifully back to Dm. And there you have your passport to introduce pitches that fall outside the key center.
Mr Perch is offline   Reply With Quote
