Originally Posted by stlthinkin
Thanks for the responses. The klone is a JHS pedal, has three op-amps, uses only 2 sides of the 3PDT switch, and passes no signal without power...so I'm pretty sure it's buffered, but I didn't trace it.
Yeah, that is buffered bypass, because IIRC, JHS used Madbeanpedals' (older revision that Brian has since changed IIRC) Sunking layout for their Klone, and the Madbean Klone matches the KC 1:1.
So no need to trace.
