Originally Posted by Pierce
I use them in guitars when solid shaft is required unless CTS has been requested.. easy to solder to also. They haven't been out 30+ years so reliability is an unknown.
If these are the same type of pots I got from Tom a couple of years ago, they're just terrific -- I've had a pair in my partscaster since then and they're still as smooth as silk. The CTS pots Fender uses are also very good, but they are stiffer to turn and if you don't turn them for a couple of weeks they get even stiffer.
