Now, I guess the only thing to decide on is if I should go with the 6L6s. (although - it's probably not hard to change that later)
I would talk to Bruce about 6L6's first, because he might be able to tweak the kit for you to use 6L6's. He also can tell you if power transformer can handle a pair of 6L6's b/c they draw significantly more heater current which the PT *might* not be able to handle. My guess is that this isn't a problem.
