Old April 10th, 2003, 01:59 AM   #6 (permalink)
MJ Harnish
MJ Harnish's Avatar
Whoa....I never thought of that! Would it work? Could a 5E3 circuit push a 15"????
There may be other problem I can foresee. Since I'd probably be buying the cabinet, there's a risk that the chassis would be too short for the opening in a Pro cabinet.
There is no problem with a tweed deluxe pushing a 15" speaker. It takes very little power to drive a speaker load; take a look at the 1/10w ZVex amp which can be used to drive a 4x12" cab for proof. Just make sure you get the correct impedance.
As for the cab, you are very likely to need a custom cab anyways, so you could get it made to fit the chassis; Armadillo Amp Works makes really nice cabs at reasonable prices.
http://www.armadilloampworks.com/
The only potential problem is that if the Mission Amp kit is meant to be mounted vertically (like the original tweeds were) you might need a pretty deep cab to clear the speaker.
Have you considered building a head? Then you could use it with whatever cab you wanted, switching to suit your needs.
MJ Harnish
Suburbs: Where they cut down all the trees and then name the streets after them.
MJ Harnish is offline   Reply With Quote
