good advice from Kevin!
Also I can say that I, once owned a 95' Tele Plus, Fitted standard with Lace Pup's, the Neck had a Blue ,and the Bridge had Red Dual's,
and a small three way toggle switch,to split them,so you could have either the Bridge , front or the rear, Pick-up individually, or both together for the Humbucking vibe!.
There was of course the normal Tele 3-way Switch, and used with the Toggle switch, there was plenty of combinations, this was one Hot Tele.
Ernie.
