Originally Posted by robbo1422
thinking out loud here, and i'm no wiring expert, but could you possibly do a five way strat normal circuit with the neck pickup on a push pull pot so you can pull it up to turn it on when your in the bridge position (thereby getting neck and bridge) and then putting a push pull on the tone pot for series/parallel wiring?
Cheers Robbo - it's definitely possible to do a 5-way circuit, and just add a switch to put the neck position on regardless of the position of the main selecter. This allows you to get all 7 possible parallel pickup combinations. It's just getting the additional series options I mention that seems trickier. But there may well be a way to achieve something like you say - I'm still thinking and looking at circuits on websites anyway, I'm sure I will be able to come up with something to suit given time.
