Old May 14th, 2011, 09:08 PM   #6 (permalink)
LightninMike
LightninMike's Avatar
levels are good..... the general areas to look at, IMHO, are the effects and a few specific eq's.... listen to the sound through a set of small speakers and then through a decent stereo system..... listening to the mix in several environments with different sized speakers/quality levels
acoustic is decent, but listen to an acoustic in a room and then listen to the recording.... match them ... you will notice the acoustic has a bit more low end in the natural room.... a nicely matched reverb will help this
the snare doesn't suit me, and i actually prefer it with the "clap" over top of it.... if you started the track with the clap and then brought the snare in as filler it would have a nice affect on the track....
the vocals need the same type of effect as the acoustic.... again, listen to her sing in a room that isn't deadened.... then listen to the recording.... in between the two is where i would put it
LightninMike is offline   Reply With Quote
