Old April 12th, 2011, 12:17 PM   #5 (permalink)
11 Gauge
11 Gauge's Avatar
Originally Posted by Jeff B. View Post
Do you have any other pots available? You could put a 3.3K or whatever size in series with a 5K pot or put a resistor in parallel with a higher value pot to divide it down to 10K.
A 5K pot is actually a decent recommendation - I find that part of the range of the 10K isn't very usable, and at "max voice," it's a bit too bright.
2.2K in series with a 5K pot will give you most of the stock 10K/1K range. The other benefit is that at "max voice," you basically have the "2X gain" mod from a TS - a 2.2K resistor paired with a .1uF capacitor.
Keep in mind that if you stick with a higher value fixed resistor that you'll want to match that value on the gain pot.
