Is this a closet Stratocaster thread?
Mine's set up thus:
All 6 screws down tight.
All springs pulled tight back.
Don't even think about whammy, or the body will crack (due to the tight screws).
I found a long time ago that I didn't really use the whammy, so disabled it. More sustain, and better tuning stability. If I want to bend a note down, then a bit of forwards pressure behind the neck usually suffices!
There was the one gig, though, when the guitar went way out of tune - yup, the neck screws had worked very slightly loose!
