Old April 19th, 2005, 09:00 AM   #3 (permalink)
teledude66
teledude66's Avatar
Re: i had the same kinda trouble
Originally Posted by popthree
i ran into a latency problem while using my notebook to record...mainly because my soundcard just doesn't have the processing power to be great at multitracking.
the way i solved the problem was to monitor whats coming out of the mixer instead of whats coming out of the pc.
i take the signal from my pc and pipe it back thru the mixer ....then monitor that signal, and play along with it.
(instead of plugging headphones into the headphone jack, i ran a patch cable from the headphone jack to the mixer...and plug my headphones into the mixer)
sounds complicated..but it makes sense once you lay it all out.
i think this is how i do it also...to clarify i use aux sends to line in on my soundcard the speaker out on the soundcard into the aux returns on my mixer and use the headphone jack on my mixer for monitoring ...i use to go from the line in/line out but then i discovered feedback loops ...lol
The fact that no one understands you doesn't mean you're an artist.
teledude66 is offline   Reply With Quote
