Originally Posted by silentechoes
Could be a ground loop caused by the 1 spot. Could also be that the pedals don't play well together, I've had this problem different times.
My current od setup consists of a Barber Direct Drive cascading into a Fulltone OCD. Before that it was the MXR Wylde od into the OCD. Both of these setups worked well.
My favorite pedal for getting Hillsong tones is the Direct Drive though. If you pull the tone knob, and set everything at noon that seems to really nail their sound.
how can i fix the ground loop problem and the pedals that don't work together? do i have to change the sequence or do i have to remove one and check the compatibility for to pedals?
so your ocd is the boost and your main drive is the barber am i correct?
thanks
