Old November 4th, 2010, 01:06 PM   #3 (permalink)
Jeff B.
Jeff B.'s Avatar
You can use screws/nuts, rivets, epoxy, strong double-sided tape, glue, run a piece of heavy bus gage wire between the jacks and solder the terminal strip to that or glue/epoxy the mounting nuts inside and mount it to that with short screws. If the enclosure is steel you could spot weld on the inside. That's about all I can think of.
Jeff B. is offline   Reply With Quote
