I did a similar job on a tele copy a couple of years ago, I replied to a similar question that was back on page 8. I used a cheap gibson style tailpiece which I shaped using files and wire wool. I used a radius template to get the curve of the bridge right and shaped it into a ridge more like the original LP Junior bridges. For positioning I used the original tele bridge and marked this onto paper I stuck on either side. With a lot of fettling I managed to end up with no neck shim and the bridge/tailpiece screwed down to the body. I used a few sets of strings though. Instead of using the holes in the bridge I kept it as a string through, which keeps the string spacing right. Anyway it works and I think it sounds great. Good luck!
