Old August 12th, 2010, 12:40 AM   #5 (permalink)
BelairPlayer
BelairPlayer's Avatar
I think you're describing a particularly bad fret buzz, no? I think when you put your finger over the string at/near the nut your altering the normal vibrating pattern of the open string near the fret its buzzing at.
Obvious possible causes, poorly cut nut (too deep), or truss rod poorly adjusted, or perhaps high fret near the nut.
Probably just in need of a good setup.
BelairPlayer is offline   Reply With Quote
