Just run a line from the Effects loop send(preamp out) on the amp you are plugged into - to the Effects Return (preamp in) of the other amp. You could also run a speaker cable off the other speaker out jack on one Deluxe to the cab/speaker of the second amp. (this means having to have a "female" connection where the 1/4" jack of the speaker can be plugged into the "extension" speaker cable.
