Jackhole Drilled
7/8 inch jack hole drilled. Does the Telecaster cup type jack require further modification? I ain't got my heart set on it. Just wondering. I can always install a flat plate type jack holder.
Stained the top with orange amber shellac.Stained sides and back. Put a couple coats of Deft Sanding Sealer on the back and sides. Installed binding. Scraped and sanded. Restained sides after sanding off all the sealer and much of the stain.
I used hair tint for stain. Redken Shades EQ color gloss. 09A Papaya. Wiped on straight with no developer (low volume peroxide). Its the same as I used on build number one.
