| 2012 TDPRI Tele Build Challenge 2012 Build Challenge Forum -- check out all the build threads for this year's Challenge. |
#41 (permalink) |
The weather here has been miserable all day with light rain and wind and as I work in the open roller door of my sawdust factory because I have trouble under fluoros having done it for 40+ years (and now it just gives me eyestrain) I didn't achieve much today.
This afternoon only really made a centre reinforcing assembly out of the two remaining 35 x 19 x 800mm sticks I cut before, well didn't actually use all of the second one. Hope I've got the lumps and gaps in the right places.
" I have this piece of wood that I've cut three times and it's still too short! " |
#42 (permalink) |
Nice looking work Dave and loved seeing the kerfing jig. It did my head in trying to work out how it worked but I think I have it sussed out now :-) Kudos to the person who thought it up in the first place - was it you?
The top looks beautiful and the way you dressed up the Tassie Oak grain was also ingenious. The red gum detailing around the f hole also sets it off nicely. Did you say you are going to use Meranti - probably my least favourite wood - but whatever you do with it I'm sure it will be amazing. |
#43 (permalink) | |
http://home.provide.net/~cfh/coronet.html (just scroll down a bit) Really nice and original build. Cheers. |
#44 (permalink) | |
If you want a better look at the kerf thing let me know and I'll post some close-ups. DC
#45 (permalink) | |
#47 (permalink) |
Hasn't got to the interesting bits yet John. Wish I could do them like you!
Dave
#48 (permalink) |
Still here
Hi all Well it's down to the body building part. Originally planned on using the everpopular Tassie Oak so cut and thicknessed some TO to 36mmX2mm and took to the hot pipe bender thing.
Let me tell you Tassie Oak bends like spring steel and tighter bends dont break but they sort of flake off the top surface. So out with the Sassafrass block and cut and thicknessed to 36mmx 1.5mm. With the sassafrass you just have to wave it over the mould and it just jumps into shape. Clamped and leave alone overnight.
#49 (permalink) |
The hot pipe!!
I bent the sides on my executive model wood bender thingy (photos attached) Didn't really get any pix of the process but when you are bending there's not much time for snaps.
This device changes each time it gets used and this version runs on a single rubber band!
#50 (permalink) |
The neck
Got out the big piece of meranti and cut a neck sized length and marked the shape and cut to 1.25" thickness. Marked out the neck shape and cut close to the line and level on the bearing guided bit on the router table.
This is a trial approach to how I build a neck usually by cutting off the "ears" around the headstock section you end up with a pointy bit of wood which hopefully will get better as we go along. Anyway, mounted the blank on the multi jig and flattened both sides with the router level planer and cut the truss rod slot in the same operation. Now off to get a hair cut!
#51 (permalink) |
Bending tassie oak is like bending mahogany - bloody tricky.
I find it's best to soak it for 10 minutes.
You need to roll the dice to be in the game. |
#52 (permalink) |
Did that but I got the feeling if I soaked it overnight it still wouldn't have bent. An overnight soak would have left it pure white I think by the amount of brown in the water after 30mins.
#57 (permalink) |
2mm seems pretty thick to be bending. If you want sides that thick, I'd suggest doing a few thinner pieces and then laminating them.
"The difference is that you're crazy like Nicolai Tesla and I'm more like the guy who sniffs paint and rides his bike down the middle of the road" - Me to Crazydave911 |
#58 (permalink) |
Scarf joint.
The weather has been miserable again! Hard to work in the rain but did manage to get the neck mounted to a straight edge guide board and got out the old 13 degree scarf cutting device/jig/thingy and chop off his nose!
Usual stuff, stuck down that cut off piece to the top, and grind away on the belt sander and sort of flatten it out a bit. Boring old photos to follow, hopefully things wil be a bit more exciting in days to come.
#59 (permalink) |
Some progress
Due to an extensive R & D program I have been undertaking for some time and at great expense to the management, I am now able to share some vital information regarding my patented " Harmonic Resonator Cavity" system.
The system of cavities consists of 6 precision milled mini containers not unlike little wooden buckets with a hole in the bottom. These are located beneath the bridge and there is one cavity allocated to each string, and of course the are the answer to all your resonance and harmonic distortion questions. Carefully calibrated to the individual strings, they will prolong sustain to extremely long time periods, eliminate feedback and protect your guitar from harmonic distortion virus. These HRC's of course have to be "forked" a process pioneered by Prof. Oigun of the Netherlands. Thank you Prof. Oigun.
#60 (permalink) |
Starting the good stuff!
Even though the weather is still cr@p, managed to get a start on gluing up the sides to the base, nothing really exciting. Spent most of the time making some little wooden clamping aids to hold it all in place while the Titebond does it's magic.
